Seanie
Hi there
thank you, so I think my choice should be Beosound Overture.
The reasons for this is the AUX for a record player with control and connection of Masterlink to a NL/ML converter.
few questions.
Does the BLI see the converter as a device? Can it be shown as a Beosound Oveture and will the record player be recognised.
Same question about the Bang and Olufsen app.
will the overture display Phono when its playing the record player or will it show AUX?
Do you select AUX on a Beo4 or Phono?
Will the HALO see the NL / ML converter as record player etc?
cheers
Sean
