Home › Forums › Product Discussion & Questions › BeoCord › Beocord 5500 Drawer Closing Noise › Reply To: Beocord 5500 Drawer Closing Noise
17 April 2022 at 19:39
#34178
Thanks Martin. This then means you need to check how long those pins are active in each direction. If the go back low once the drawer closes then I would look at the OpAmp driver circuit to see if there is a bad cap for example that is keeping the output latched.
