Home › Forums › Product Discussion & Questions › BeoCenter › BeoCenter 2600 tape speed control? › Reply To: BeoCenter 2600 tape speed control?
8 April 2022 at 19:33
#34001
You are dealing with an AC Motor running off of the mains voltage, therefore there would only be mechanical speed adjustments and they would be in the manual. I would check that all of your play adjustments as per the manual are correct as there may be insufficient tension. All the above also assume you are not trying to use a 50Hz unit on 60Hz.
