Home › Forums › General Discussion & Questions › BeoWorld Feature / Problem › How to QUOTE from a post into your reply? › Reply To: How to QUOTE from a post into your reply?
11 April 2022 at 09:57
#33922
As of this morning you will see “QUOTE” in the menu above each reply. You just press the quote link in the reply you wish to quote and it will be transferred into the reply editor at the bottom of the thread as below. Beware, if you are in the editor in “Visual” mode your typed text will enter inside the quoted text area, so I suggest you click the “Text” tab before typing your reply.
Testing my understanding. Thanks, Keith.
