Home Forums Product Discussion & Questions BeoGram BeoGram 6000 chassis suspension Reply To: BeoGram 6000 chassis suspension
#33604
Vinlyfrontier57
    Thanks again for your guidance, Mark-sf.  After lots more tweaking, I discovered how the position of the leaf springs can be adjusted just enough to centre the platter – as you pointed out in your first post.  So I’ve got it pretty much sorted now. The platter is central, and the top surface is exactly level with the cover plates  – until I place the drive belt over the motor pulley!  It’s a recently purchased replacement belt, and I suspected right from the start that it might on the short side, as it was a tight-ish fit just around the drive surface of the platter.  Can you recommend a reliable supplier for replacement belts?
