Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3500 with MCL to PowerLink Convertor. › Reply To: Beolab 3500 with MCL to PowerLink Convertor.
#123585
Madskp
GOLD Member
There is now an optional software image that just needs to be flashed on a SD card. Strictly speaking its still DIY but the software part can be plug-play with that one.
Oh very interesting 🙂 I have not read the full description yet, but will defenetly look into that.
On ML side there are two different ways of remote waking the BL3500. Either via the timer function (BL3500 needs to have TIMER ON) or just by sending a virtual Beo4 command for switching on a source. In a traditional ML system without MLGW the only option for a video or audio master to activate link nodes is broadcasting the timer activation command. All devices with TIMER ON will then switch on. With the virtual Beo4 keys you have much better control and it works on all devices I have tested.
Great info to understand it. The Almando Masterplay use the TIMER function for it to work btw.
