Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 9300 – Lid touches CD? › Reply To: Beocenter 9300 – Lid touches CD?
Hello Hiort,
It is possible to close the Beocenter incorrctly after (poor) servicing. The cd mechanism sits on 4 sprung posts to dampen vibrations – it sounds like it has not been seated correctly after a previous service.
As Chris (previous reply) states, service guides are available to gold members on this site and these will help you learn how to carefully maintain your Beocenter. The unit is extremely heavy and delicate though, so if you’re not familiar with delicate electronics I would recommend sending your Beocenter to Multicare for a full service. It’s a great system and deserves some TLC 😊
Julian
Edit: I just noticed you live in Sweden – please disregard my recommendation of sending your Beocenter to Multicare in the UK 😄
This reply was modified 6 months, 3 weeks ago by
pepps. Reason: Foolishly recommended sending the unit to the UK from Sweden
Favourite Product: Beosystem 6500
