Home › Forums › Bang & Olufsen & Your Computer › Bang & Olufsen / PC › Beoport/Beoplayer › Reply To: Beoport/Beoplayer
Can you confirm that there is still only one radio station per country shown?
As an experiment I just re-installed Beoplayer (including a registry clean up after the uninstall).
On initial re-installation there are no radio stations showing. The registry entry ‘LastUpdate’ is blank and there is no ‘UserID’ nor ‘Server URL’.
When I ran that Registry Editor file it added the ‘UserID’ and ‘Server ID’, but the ‘LastUpdate’ value was still blank.
A few minutes later all the (>1000) radio station started to appear, and on checking the Registry the ‘LastUpdate’ field was again showing ‘2021-11-15’.
You could try manually adding an ‘IntervalForCheckingUpdate’. Right click in the registry and chose ‘New’ D WORD (32-bit) value. Just name it ‘IntervalForCheckingUpdates’ and copy my Hex value of ’12c’.
(It goes without saying that you are editing your Registry at your own risk. I always carry out Registry backups before playing around!)
EDIT: I am pretty sure that the ‘IntervalForCheckingUpdates’ of 12c (300) corresponds to 300 seconds, hence it should check for updates every 5 minutes.
