Recently, I tried to play a CD on the Beocenter 8000 I have at the office. No sound came out, so walked up to the machine, opened the CD lid, and was greeted with a putrid puff of smoke *cough*
I opened the unit today. No obvious faults anywere else, but two 10 ohm resistors on the servo board are clearly damaged, and badly off value (on the right in the picture, above & below the two transistors). I dug up another same type servo board I have (probably faulty), and even on that one of these resistors has gotten brown and the resistance is too low.
These obviously belong to the spindle motor control. I tried rotating the motor by hand, it doesn't seem any tighter than normal, and whirrs away quite nicely with a 3V battery. Any ideas? I could start by replacing those resistors, but would rather not shoot in the dark and risk more damage...
While separating the servo board from the mechanism, one of the spindle motor wires came off the motor with no force at all, so there might have been a bad solder there.
Does anyone have the schematic for these later type of servo/mechanisms that have a two-wire spindle motor? I think I've gone through all relevant service manuals on site, and all of them only discuss the earlier types that have the motor control board attached to the motor itself. I could draw it off the PCB but would rather not...
