Beolink 5000 & Beocom 6000 sevice manuals?
Andy,
The front panel is available and for the Mark II version the part number is 3455019 and should cost around £15
Anybody??
"Hello,
just had another thought on the BL5000 2-way problem. When I press the STATUS button on the BL5000 it correctly gives the source information even though I haven't used it to select the source! Does this mean it IS receiving some 2-way comms? I am slightly confused! Any suggestions why it will do this but all other 2-way comms brings "no contact"??
Simon "
Andy,
yes it was from my local dealer about 2 months ago...I was well impressed!!😂
Simon
Thanks Keith and Simon👍
Andy T.
Andy,
Actually, I still do have a couple of Mark I BeoCom 6000 front panels and key pads available for purchase, but if you plan to replace one, I suggest you go the whole way and upgrade it to a Mark II for not much more cost.
Thanks for the offer Keith😁
You have PM, or at least you will in a couple tics.
Andy T.
