Well I did this but a certain amount of hum (unacceptable) did remain. I did a lot of trying, touching here and there with the ground wire but apart from a little reduction the hum was always there. It COMPLETELY/ABSOLUTELY stopped when I run a wire from the earthing screw of the amp to the aluminium "box" of the carriage. I mean COMPLETELY. EUREKA. Now: the carriage moves. Where do I screw a wire that makes the same effect? Why do this happen?You probably need to run a ground wire from the chassis of the Beogram to the earthing screw on your amp.
Loris
