Beosystem 1 - IR Receiver
Hi Michael,
 This was the original connection that I tried but could not get it to work. Frustrated I stopped by the B&O store yesterday and purchased a new IR puck and everything works. The salesman at the store did not feel the IR puck from the active link would work but was not sure why.
Thanks to everyone for their suggestions.
hello?
how much is IR puck?
thanks
Hello!
I managed to hook an IR eye from a beolink active to the BeoLink PC2. Check my other posts.
I was wondering if you are willing to test the connection in my post on your Beosystem.
I tried to use the same IR eye with my Beosystem 2 and it didn't work. However, my Beosystem 2 is (almost dead). I'll check if the connections are the same for BeoLink and Beosystem with the oscilloscope tomorrow and I'll let you know if you need to swap wires or not.
Regards,
Andrei
