Beosystem 1 - IR Receiver
Purchased a used Beosystem 1 but the IR receiver was not included. My question is can I use the IR receiver from a BeoLink Active kit. The wiring diagram for the Beolink is different than the wiring shown in the Beosystem 1 reference manual. Beolink shows 1=yellow, 2=grey, 3=Green, 4=White, 5=Brown. The Beosystem 1 shows 3=Green, 4=Yellow, 5=Brown. Any comments would be greatly appreciated.
http://www.beoworld.org/beotech/ir_eye_wiring.htm
It seems you need black yellow and green or does the BS1 have a different connector?
Cheers
JK
The BeoSystem has a single (three wire) plug similar to that found on headphones, whereas, the plug with the Beolink Active is a 7 pin DIN type connector. It is quite possible that the two are not interchangable.
 Thanks Ron
I think that is described in  the wiring diagram that I am linking to. Only thing is, you do not mention black which it has.
Cheers
JK
The connector that I purchased for the beosystem 1 from the Bang and Olufsen store does not have a black wire and the wiring diagram I downloaded from this Forum for the beosystem one shows only green yellow and brown. I am wondering if  because the IR receiver that I have with the beolink active is connected to a beolink connection box if there is something different in this IR receiver.
I appreciate your input.
I think the IR receiver that is normally used for beovisions would be an IR eye only, no additional buttons. The one that is used for Beolink active has additonal buttons, i.e. for volume so there would be more cables.
I think I would give it a try though.
Thanks jk1002,
 I will try a couple of combinations this weekend. Will let you kown how I make out.
I'm pretty sure it will work with any IR eye as long as you make the right connections.  I've used the BS1 with the newer BS3 IR eye ( in your diagram) with the light sensor etc on it and it works just fine despite having a different terminal arrangement then the active kit eye.  AFAIK the eye for the BS1 was the same as the active kit electronically.  The only difference being the absence of markings on the front of the case (vol, ^, v etc.) for the BS1.  As I recall it was pretty straight forward to make a custom cable with an old mini stereo plug and some ethernet cable.  I believe cat5 is actually what some installers use for the eyes when they do custom cables.  The diagram you have is for the newer eye but they are similar in wiring to the 5 connector BS1/Active eye.  I couldn't find the diagram for the active/BS1 eye on Beotech for some reason.  I did, however, find the a correct wiring for it here in the ActiveLink Reference manual on page 5.  Just keep in mind that you only need the three connections in the correct ports:
http://www.beoworld.org/manuals_view.asp?pid=980
Hi Michael,
Thanks for the link. I checked it out and it shows the same 5 wire connections that I have for the beolink active. The difference between this diagram and the one with the Beosystem 1 is the yellow wire. It is shown on pin 4 on the Beosystem 1 and pin 1 on the active link. I tried these two combination but neither seemed to work. The Beosystem 1 shows only 3 wires. I am out of town this week so I am going to try to connect the beolink active up through the proper junction box and see if it is actually working when connected up to all five pins. I did call our location B&O store and they said I need to buy the standard "puck" as they referred to it. Still think this IR should work but it all else fails I will buy a new IR puck.
thanks
Ron
You are right. I mistakenly stated that the link was the correct wiring.  What I meant to say was that it was the correct "puck" ( as opposed to the one in the previous link).
If it still helps anyone I finally found a picture of the correct puck and wiring out of the BS1 Guide.
