Bought a cd4500 off ebay - got it for a steal cause although cosmetically perfect the disc would not turn. After opening it up (and testing with a disc) I saw that the laser arm would move back and forth but again the issue was the disc would not turn. Today I replaced the 2103 cap with a Vishay 25V 47uf axial cap. After install (still with the covers and back off), I plugged it in put in a disc and was happy to see the disc turning a full speed (with the laser engaged under the disc). But the unit would not be able to read the disc and after about 5 seconds it would stop and retry (stop spinning and then restart spinning) - after about 4 tries it goes into standby.
I tried it a few more times, and unfortunately now the disc again is not turning. I also see the laser arm isn't swinging in/out much anymore (it moves a few millimiters but is no longer swinging to the end position like it used to).
So would really appreciate some advice where to look next. Looking at under the cd mech it doesn't appear this model uses a belt and rather looks all electrical, but again maybe I'm missing something.
Also I have a dumb question - when I removed the old cap I failed to take a good look to see which way the pos and neg was - so I found the schematic and BELIEVE the neg is on the side closest to the edge while the pos it beside the square boxy thing - that is how I installed the new cap. Can someone confirm I installed it right - I'm pritty sure I did but now that it is still not working maybe that could be the issue (but I doubt it as I suspect installing the cap backwards would cause some major issue which would be obvious)
Last question - looking at the spindle motor schematic, it shows the board has VC, ground, -2 (-9.5V), and 2 (+9.5V) which is feed from the servo board plug. The servo board plug has the posts visible on the side - can I feed these posts with DC power to confirm the spindle motor is good - or can I use my multimeter to confirm the proper DC power is being sent to the spindle motor board? If so, what exactly is the VC, and the +9.5 vs -9.5 mean. Does this mean if I put the neg lead on my multi to the negative post and then the positive lead to the VC that I should see ~12DCV and if putting the pos lead to the +9.5 post I should get 9.5DCV and if I put the positive lead to the -9.5 post should see -9.5DCV? If I had a 12DVC and 9.5DCV power supply, can I supply power to these posts to see if the spindle motor turns - if so which power makes the spindle motor turn - the 12DCV, 9.5DCV or -9.5DCV? Thanks
