MMC Pickup repair
Hello again, hope everyone had a good time, did not have much time to write but I've had time to buy some tools and will soon make an attempt to serve a MMC needle.
Will tell you more and add some pictures.
Have a good time, as long as you wait for pictures.
Best regards
I'm really interested in seeing how this works out for you. I am pretty sure I don't have the manual dexterity or steady hands for this, but am very interested in how this would be done.
I am trying to send Axel S an e-mail, but the are using an insane kind of Prüfcode.
I had a loose cantilever, so got to open the cartridge. Now what should I do? Re-glue the cantilever cross to the suspension? Are there supposed to be any wire connections on the back?
Thanks for any help :)
[View:http://www.vinylengine.com/turntable_forum/download/file.php?id=27999&mode=view:800:0]
Audio Origin UK based B&O cartridge and stylus repairs,
http://www.audio-origin.co.uk/retipping-stylus.html
Best regards Alistair
pity, the photo is not online anymore😮😕
sorry I send it twice
at
The bonded sphericals that Axel used were of poor quality (I had two done - the microscope tells the truth).
I do hope Alistair does a better job.
Jacques, what microscope you use to inspect your needles?  I'm looking for one but don't want to spend thousands on this alone...
Thanks!
