MMC Pickup repair
Hi thinking of how to repair a mmc pickup. has or does anyone know how to do it?
Can be put into an existing MMC a replacement needle?
Is there such a needle on the market?
Regards
Jan
You can't just purchase an off-the-shelf replacement needle - the cartridge must be rebuilt.    And the best, most economical service to use for this is
thanks for your reply. do you know where I can buy a off-the-shelf replacement needle?
Because I want to be able to rebuilt the cartidge, I want to ask the question again how to do this?
I have many customers who purchase or comes to service with a broken mmc needle. I serve many B & O products, but has not serviced a mmc needle, but would like to provide service in mmc needle.
grateful for all the responses and info
Best regards
Jan
Many repairers would like to service MMC cartridges but it's not very easy.
The easiest thing would be to take a stylus off another quality brand and then transfer to the
tiny rubber support inside the MMC cartridge.
But do you have the method, skills and tools for getting into the MMC cartridge to do the job - and out again ?
Hi Martin, I actually do not have method, skills and tools. Ok I have been working for 30 years with the Service of TV and stereo, and maybe my tools enough, I also have a Carl Zeiss microscope Axiolab that yes can be good to have.
Which replacement needle would fit on mmc pickup?
What tools are needed?
With best regards
Jan
Here a pic of a MMC cartridge
The biggest problems are broken cantilevers and the elastomer suspension getting old. The needle (diamond) comes in different qualities and forms, depending on the MMC number, the cantilever comes in different materials, aluminum, platinum.
Your problem will be: First to disassemble the cartridge without doing any forther damage, second attach the new cantilever (with the correct needle inserted in the cantilever) to the micro cross, third, find the correct elastomer and attach that in the correct way. 4th, assemble it all correctly. 5th, test and measure for correct function.
As I repair printing machines from 1 to 70 tons I cant help you with the tools, my smallest tool is a 7 mm fork/star wrench
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Thanks it's actually a great photo, just as I was looking for. generally mmc20 needle less expensive to get in Sweden and maybe the needle from a mmc20 would fit on a mmc? correct me if I'm wrong.
The problem is not primarily (Tools or skills) tools, we can buy and knowledge hopefully get me here more, of all, the members of beoworld.
Then, it just serves a mmc, it will be already broken so if I do not succeed it does not matter it was already broken.
obviously all the information I can get here on beoworld so I can more quickly manage to serve a mmc pickups. If looking Google? so is there no information how to serve them. It would be nice to finally have a light on these secret and make it possible in the future that many others can serve a mmc pickup.
So I thank for all the answers I can get, even if you think it might is not right or stupid, get in touch for that in context, it may be the solution.
Best regards
Jan
A video of Der Meister (Axel) at work
MediaBobNY wrote:
 You can often find people selling defective MMC's on eBay for you to practice on.
But now even broken B&O command silly high prices, unfortunately. I've seen people bidding on broken carts up to really preposterous amounts. 😎
Jan maybe you should try to contact the other Swedish members, and make with them a joint effort, there are members from Stockholm, Örebro and Halmstad as far as I remember. Some of these members must have cartridges to start on.
Retired
Rock and Roll music
Collecting Vinyl
