Hi all,
I was quite lucky to be able to complement my exsting Setup (BS2 and a Shape /w Essence remote) with a "second life" BLGW, which I have reset to factory defaults and started adding some macros for testing. I would appreciate if you could correct me in case I am on the wrong track... What I would like to achieve is that when volume is adjusted on any one device, the other one sets itself automatically to the same volume. Also when one of the two is switched on or off, the other one should switch itself on or off, too.
Can/should I use STATE_UPDATE for this purpose? The volume can be set e.g. by the following macro:
Event:
Main/*/AV renderer/BeoSound Shape/STATE_UPDATE?volume=25!
Command:
Main/Shape_Wohnzimmer/AV renderer/BeoSound Shape/Volume level?Level=25
Then cloning/adding this macro for each volume level between 12 and 50, and for each device. Is there a better way than one above to achieve this, making sure volume levels are identical on all devices at all times?
