Hi all. I've ordered some days ago a faulty LC2 dimmer at good price from a guy of this forum (thanks to him).
symptoms: the touch was working but not the IR
Here is my repair story if it can help someone.
here is the faulty board
Login to view image
you can see the IR board on a little PCB.
Login to view image
the system is connected to the main so you must disconnect it from the mainboard to work on it
Login to view image
Login to view image
and use a power supply to safely test the circuit.
Login to view image
the PCB uses 3 pins. two for power and one for received IR burst.
the ground is the black the red is the +5v and the white is the output
here is the schematic from the service manual
Login to view image
using a scope and after powering the circuit under 5v I've got this trace at the output
Login to view image
With or without IR light from a remote there's some random burst -> stange so I'm trying to find where the IR light is stopped.
Here is the trace at the point A when pushing a button on the remote
Login to view image
Well the bursts are received by the photodiodes.
now at the point B i've got
Login to view image
So the discrete 455KHz tuned amplifier works too
and now at the point C
Login to view image
huh! nothing! Huston? we have a problem! the U2506 input has an offset and seems to have a low input impedance.....
ok now let's check the other signals. test the ref voltage at the point D
Login to view image
Wow! noisy ref voltage! even if we are near the 2.35v value from the datasheet there's definitively something wrong!
looking closely to the PCB something was strange:
Login to view image
with the binocular
Login to view image
the capacitor pin was corroded -> electrolyte leakage! here is the culprit! The leakage has corroded the capacitor copper pin and the ref voltage is no more filtered
Eeven taking lot of care when removing it the ground pin was torn from the PCB
Login to view image
the capacitors are two 22uF 6.3V with 4mm diameter
Login to view image
and 5.5mm heigh
Login to view image
I've found a good replacement from Panasonic FK serie 105°C even if the original one is a standard (not low ESR and 85°C)
Login to view image
Login to view image
after modifying the copper to reconnect the ground of the capacitor (removing green varnish)
Login to view image
Login to view image
the capacitors were replaced with a ground wire
Login to view image
now here is the reference voltage measurement at point D
Login to view image
Well! much better!!
and now the output signal of the IR board with IR signals coming from the beolink1000
Login to view image
It's alive! the circuit is now working!
we can close the metal shield
Login to view image
put it back on the main PCB and voilà!
Login to view image
the dimmer is now working well \o/
I hope this post will help someone :)
