I just got a BS4 for 60 euro, glass did not move, and was very loose, and all the rubber is starting to turn into goo, otherwise, everything works fine :)
Glassdoor is as simple as a broken belt, but B&O(at least in DK) will not sell me one as spare part, they will only take the complete unit in for repair, which in turn means a cost of 3-4 times the price I bought the unit for, for a single belt !!
Come on B&O, let us keep some of the old stuff alive by our selves !!
Oh well, the question is, does anyone know where to source a belt of the correct size ?
Thanks.
P.S I have removed the black goo on the front panel, and cd-bay with nail-polish, and after some plastic primer, and mat black spray paint, it looks a million again :) Now just need to do it on the body also...
/Weebyx
