Hi there
I´ve bought a Beomaster 6000 wich was not working at all. I knew this before that there was no funktion at all.
My thoughts were to recap and resolder the PCB´s make some finetuning and cosmetics and get it back to life...
But the restauration seems not as simple as as i thought.
What have we got so far?
The Beomaster doesn´t start up, there are
2 lightbulbs from the tuner mid alignment
one decimal point and the
doublepoint on the display lightened up.
No click from the relay.
No response from any button pressed.
Already tested and confirmed
Frequency 3.975 Mhz on Pin 1 IC 4
Frequency 664 Hz on PIN 15 IC4
Reset seems to be good, high level comes with a short delay after the 5 Volt rail voltage.
Reset function tested with Test Reset at TP 1.
All rail voltages incl. 6,5 Volt, 5 Volt on the PCB´s are OK
I´ve recapped all the capacitators on the PCB´s except the power amplifier.
Resoldered all sockets and joints on the uC Board
I messed around with the divided frequency of the tuner on PIN 38 IC4, there is no signal at all. The signal is ending up in the small piggi board with is not inserted in the schematic.
On this board there is a 74LS74. The signals on the inputs there are present but not at the output to PIN 38 of IC4.
There is a long discussion of that problem in another thread started from Sonavor, here is the link for all who are interested:
/forum/the-workbench/beomaster-6000-refurbish
The problem is solved in a way i didn´t realy understand, but in my opinion the board is part of the dividing stages of the tuner to make it useable for the uC to display the tuners frequency.. ( i hope you understand what i mean so far ;-))
Sonavors Beomaster was already running and he had the stucked frequency display issue.
What i´ve found out is another issue that the 6,5 Volt rail is drawing a current about 300mA in this state of the Beogram.
The heatsink of the power suply is getting handwarm.
I seperated the 6,5 Volts from the 5 Volt rail which is generated trough TR1 and the current is falling down to about 100mA, that means that the 5 Volt rail draws a current about 200 mA, in my opinion too much.
Resistor 6 on Board No. 6 is getting warm but not steaming or smelling, it drives the current of one of the lamps wich is on.
My first question is:
I´ve pulled the powersocket from the amplifier (+ - 50 Volt) to prevent the amplifier of going up in smoke. Is there a relation between the amplifier and the startup of the beomaster?
Second question:
I´ve inserted a signal of about 2 Mhz via a 1 kilohm resistor to PIN 38 (Frequency counter) of IC4 from my generator.
When i give a little minus offset the relay is clicking and gives power to the amplifier.🤔
There is no change of PIN´s 18 STBY and 19 FAULT SWITCH, they stay in low level about 0,3 volts.
With powered on amplifier nothing changes in the display, and no response of pressing any button.
Now i´ve been messing around for two days with this beast and still in the beginning and going in circles. No success so far.
But i trie not to give up, there must be a solution of this problem ;-))
I hope to get some little help from you.
Maybe someone has just one Beomaster 6000 on his workbench.
The best would be that someone of you is able to test my uP Board in his Beomaster or just test the uP IC4 itself.
Are there any spareparts avaiable?
I´ve made a lot of pictures of the signals that i´ve measured but in the moment it takes very long to upload them. I think i have to rezise them a little bit.
That´s all for today
Going to sleep.
Best regards
Christian
