Hi to all,
I've got a Beomaster 2200 in restoration now. The 1.6A fuse from is constantly blowing. I disconnected the power supply module from the main board, fuse is still blowing, so I assumed the problem is with the power supply.
When I disconnect the power supply module from the secondaries of the transformer, it's fine, so I assumed, the transformer is fine.
The electolytics are changed for the new ones - no change. Is there anything special I should check in this power supply? Seems like transistors and diodes are OK. Does anyone know what is the SBT1 and its values? (shown on my pic.) I found nothing about it in the service manual... Thank you!
