Beomaster 1900 quiet muffled left channel
Hi folks,
I'm working through fixing up a Beomaster 1900 I bought a few weeks ago for a bargain.
The left channel is sounding muffled or hollow in the midrange.  I have tested this for Tape in (playing an Ipod) and for FM, and for speakers A, B and headphones out.  And I'm about 90% sure it actually had this problem before I started fiddling with it.
I bought the lights/ capacitors/ rectifier from Dillen on this forum, and replaced all of them, successfully I think.  I replaced them because the volume control was stuck on full, and several of the lights were out.  Replacing the volume control lights alone actually fixed this problem, but I went ahead and replaced the capacitors as well.
Incidentally the 'Loudness' button gives of a lot of crackle when its switched, I'll have a look at the wiring behind it shortly.
Any ideas???
Cheers, Nataniel.
Does anyone have a suggestion for what might be causing the muffled left channel?  And how to fix it?
Cheers.
A defective tonecontrol slider, - perhaps the treble ?
maybe you can sell him one of them too ay?....pfft
frrrt
sounds more likely to be a poor signal connection due to a faulty balance slider....and if it isn't broken already, I think it would be a good idea to de solder the balance potentiometer (slider) and put a drop of glue on the plastic clip that holds the two plates on to reinforce it....as this part will inevitably break......
here is a link
I don't need to sell anything but occasionally someone needs to buy something.
Advice is always free.
To place sales/wanted ads a minimum of silver membership is asked for.
What was that in your other post ?
OK, here's an update....
I have pulled apart the three sliders/pots and cleaned them.  All contacts were in place and intact.  The problem is still there.  Just to clarify - I do get a response out of all the sliders, on both channels.
The same problem is there - my right channel sounds great, left channel sounds flat, hollow, muffled.  Is there any way to further diagnose what could be wrong?
Any ideas please?? I really want to get this think working properly!
Dear True Blue
I believe you should calm down with this kind of overstated comment.
Regarding B&O products Mr Martin DILLEN is the technical reference and is always available for guiding.
In addition the 1900/2400 is the one he knows a lot.
Enjoy your B&O experience
Alain
Dear True Blue,
Alain
