Hi folks,
I'm working through fixing up a Beomaster 1900 I bought a few weeks ago for a bargain.
The left channel is sounding muffled or hollow in the midrange. I have tested this for Tape in (playing an Ipod) and for FM, and for speakers A, B and headphones out. And I'm about 90% sure it actually had this problem before I started fiddling with it.
I bought the lights/ capacitors/ rectifier from Dillen on this forum, and replaced all of them, successfully I think. I replaced them because the volume control was stuck on full, and several of the lights were out. Replacing the volume control lights alone actually fixed this problem, but I went ahead and replaced the capacitors as well.
Incidentally the 'Loudness' button gives of a lot of crackle when its switched, I'll have a look at the wiring behind it shortly.
Any ideas???
Cheers, Nataniel.
