Hi all,
Hopefully someone can help me out with this one, I recently attempted to restore a 1900-2 with Martins cap kit and rectifier - thanks by the way - but when I put it all together and turned it on there was nothing. All the lights etc. worked before but when I tested it there were no lights or turning on noise from speakers.
The only thing I soldered apart from the caps was 2/4 wires on the on/off switch so that i could take it apart. The wires are definitely back the right way around!
Anything I could have damaged in assembly? Or how I can diagnose any common issues? I have pictures, please note I broke one of the fuses on second disassembly so that wasn't the issue but you may see one weird looking fuse on these pictures.
Thanks, appreciate any help, could be something so simple!
