Beomaster 1000 back to life!
I am very optimistic!
Here's the Beomaster 1000, type 2317, series 17 that Dave Farr kindly donated to me.
I haven't done anything yet - the power lead is chopped anyway - just a little bit of dusting and cleaning, you know, dessicated (!) bugs, cobwebs and loads of thick dust, to present it here.
Fortunately, it was not used at a smokers's house, or in a kitchen, so the dust was not greasy or anything. Just loads of it! For instance, the wires instantly got clean after dusting off with a painter's brush. Good!
Such a huge quantity of dust reminds me of my tube TV repairing days!
A few crusty, leaky ROE caps in there!
The tuner string is still in place and the mechanism works smoothly and silently.
Following with interest! Keen to see how you get on with this one!
Ben
interesting stuff! Have a couple of vintage beomasters and beolabs 1700 up for overhaul to when I find the time to do so. You think the big caps can still be replaced with new ones?
good luck
Nothing wrong with optimism Jacques!
I'm also following this with interest as it will give me some hints on looking after the other 2 I have (one black keyed and one ivory keys).
I hadn't even looked into this one but it seemed so unmolested that I thought it had a good chance in the right hands.
Dave.
Thanks for the compliment Dave!
Next step, make a list of components, and do the same for the Beocord, then place the order. Quite a bit of work, this!
I could not find any Beomaster 1000 restoration thread anywhere, so I will do this from scratch, testing components one by one.
But courtesy of Beoworld, I do have the service manual! ๐Ÿ™‚
good luck
Of course they can!
Thanks, but luck is not a factor - Lindsey Bud, The Abyss.
Here is my thread Jacques, did as you, opened, cleaned and will order parts from Martin, I hope he has kits for these.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Oh good!
The search engine could not find  it! Perhaps because you entitled it BM 1000, not Beomaster 1000!
Thank you!
By the way Sรธren, putting the switches push buttons all back in place in one operation was easy on my example, on both sides. ๐Ÿ˜•
Martin strongly advises to replace the power cap, because it has a tendency to blow, apparently... Will do.
I tried hard, but no way i could do it. But taking off the keys, made it easier to get them clean on the laterals.
Retired
Rock and Roll music
Collecting Vinyl
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
