Hi all,
I've just treated myself to a Beomaster 7000 to replace my 5500. I also bought a Beolink 7000 a few months ago when I was offered one, and was looking forward to being able to use it.
However - I've just tried it on the Beomaster 7000 and it does not register any contact with the system - it only works one way. Fortunately my MCP 5500 works both ways which presumably means the Beomaster is OK, and there is an issue with the Beolink.
I replaced the two batteries in the Beolink when I bought it - but not the caps which I now gather can cause problems with receiving of signals. Before I resort to dismantling it all over again - is there anything else simple it can be? Presumably there is no setting on the remote I need to configure?
If I do have to replace the caps I might bite the bullet and replace the luminescent film at the same time.
Mark
