Beolab 8000 MK1
Changed the foam and repaired the power board after the old foam damaged the printed circuit . But is not getting from stand-by anymore so only the red led burning and the relay is not coming in . Switched the power-board with my  good amplifier board from the other dismantled Beolab but works okay together . So my problem must be in the other original amplifier board . So any idea's where to look at now ? Before dismantling and the repair off the power board this Beolab was normal working . Thanks 🙂
mr
Problem solved and TR11 was the problem . Beolab in working order again 🙂
mr
Good to hear - beautiful speakers well worth fixing!
