Hi Everyone,
I'm a newbie to Beoworld but have been very into Bang and Olufsen since first seeing it in the local showroom window in the early 80s. I've accumulated quite a mix of equipment over the years, but a recent purchase has me stumped and I thought I'd ask the people who know for advice :)
I just took a chance of buying a Beogram CD5500 to upgrade from my CD50. When I bought it I was told it hadn't been used for 15 or so years, and it certainly looked like it! It has a few issues, and whilst I'm going to swap out the caps etc which should hopefully resurrect it I wanted to make sure it was worth doing as there are more faults than the usual CD read issue (which it also has).
Firstly the CD tray will not eject. The belt, mechanism etc seems OK - but the motor only seems to get 0.4v which is not enough to get it moving. Could this be a cap issue or something more serious?
Secondly - the laser almost seems loose! The laser assembly moves very very freely and - I could almost blow on it to get it to move to its maximum extent. If you move it gently with the unit powered down it will move to and fro and take a few seconds to come to rest. When I manually insert a CD and try to play it it does move to the centre of the disc - but I'm still not convinced this is correct. I didn't want to start recapping if it has a dead laser mechanism. Does this sound right?
I'm hoping I can fix the above issues and add another fantastic CD player to my collection.
Thanks for your help :)
Mark
