Hello fellow beo lovers. I am finally getting around to tackling this cd-50. I completed the BM 5000 months ago and have been enjoying its tuner and streaming from phone. The cd-50 powered up but the cd tray didn't function properly. I completely disassembled the unit to its chassis and received a new belt and also replaced all caps. The caps I used were all nichicons (PW,KT,FG & KS series) and some of my selections were based on guessing which type to use lol. I've read a few threads from this forum on working on this unit (thanks...big help!). Cant remember all you guys names but im sure you know who you are. I performed the cd drive motor tear down/clean/lube. Not easy but again having the forum thread to consult helped. All pc boards were washed in iso alchohol then followed up with mean green then rinse. The former owner smoked so almost every part was washed. I do have a bunch of pictures that I uploaded from my phone to photobucket so after this post I will try and post them....boring thread w/o pics lol.
So this is were I'm at. Late last night I powered the cd-50 up and the tray opened without a hitch. Loaded cd upside down then pressed drawer. The tray closed and cd attatched to spindle but nothing else happened. Started to panic! I repeated the load step and bingo..the cd started spinning. forgot to mention that I didn't have the outputs connected to a receiver at this point. so the cd was spinning but then the motor stared to slow down. Took motor apart and loosened the brass pressure ring. Bingo running smooth. Wired rca's to rotel stereo and beautiful music played!
Now here is the problem...every cd I've played/tried will start skipping every so often. Some more than others. Some of these cd's have almost no scratches. So were do I go from here?? thanks
