Hi!
I managed to make my CD 3300 run again and play my CDs, but I'd like to change the supply to 240 V~ instead of the 220 V~ it is originally set to. The schematics show a pin #5 for additional 20 V~, so connecting the line that is currently at pin #4 to this one should do the job. Unfortunately I can not find this pin #5 since the transformer has only three: two on the left and one on the right hand side. Resistance between the two on the left side (currently in use) is around 60 ohms. Between the leftmost and rightmost connector resistance is around 0.5 ohms lower, so the right one can not be the one for additional 20 V~, right?
Thanks for any idea on this
Ingo
