HI all
I have aquired a beogram 6002 but the motor is making a sort of clicking noise while rotating. It does rotate good though.
The noise is also there when i turn the motor by hand, so i don't think it has anything to do with old caps.The motor can only turn to one direction, when i try gently to turn it the wrong side it is stuck there. is that normal?
Does anybody know if this is fixable or do i need a new motor?
If needed, i can record it.
