Dear Workbench,
There are lots of archived discussions on problems with tonearm movement on Beogram 4000/2/4 and 6000s and it seems that freeing the seized lubricated points on the mechanism is the solution, when there is that click of the solenoid.
My 4002's arm moves perfectly, senses the record, stops; then I don't get a click or a drop.
The only post which touches on this problem says that freeing the mech is the answer, barring 'a serious electrical problem', which seems rather ominous: So I ask, nervously—
What kind of problem is there if there is no click of the solenoid?
