Hi!
The CD player in my Beocenter 9500 was having trouble reading the CD, so I replaced the famous C2103 capacitor from the kit found at Beoparts Shop which solved that problem!
At that time, I did not change the other capacitors included in the kit, since I figured "don't fix what's not broken".
However, after playing any CD for only a few minutes, a faint static noise can be heard which slowly increases in volume and the sound becomes more and more distorted at the same time. After only a minute or so, the static takes over completely. It is the same when listening via headphones as well as via Powerlink speakers.
Switching to any other source shows no hint of the problem. And switching back to the CD after a minute, the static has decreased but starts building again which made me think it is probably one of the other capacitors fault.
After this, I replaced the other five capacitors from the kit but unfortunately, the behaviour is unchanged.
Do you have any suggestions what could cause this? Is it likely another component on the CD board or are there parts on any other board that only the CD uses in the output? On Diagram C, it says "Power Supply and Output Ampl. for 16 bit CD version". Could that be involved? Or PCB31 "Decoder"?
Any advice where to start looking is appreciated!
