This BC7002 has been working without fault for 6 weeks. Today I noticed the vu leds were on when playing a record or when using radio, this was intermittent and did not bother me.
Then when playing tape fault happened all LEDs lit and a loud Machine Gun effect on the audio.
I have disconnected set from mains supply for 5 minutes, but same intermittent results when plugged in again.
I see C9 C10 C11 could cause the fault and I intend replacing them first. The display is not always "full on" with red LEDs flashing, sometimes 1 green LED is on, sometimes more are on.
I have had a lot of time looking at the circuit and can not find where the wires from Plug 29 go. Had a good look on Diagrams 2 and 5. help please.
I do not want to do a blanket change of caps, Could dirty contacts on a relay cause this fault?
I have never tried to set the timer for the tape.
Any Ideas of fault before I open set up.
TFL, John.
