I recently updated ny Mac software to 10.12 but I am not able to connect BeoMaster 5 via the Beoconnect application.
Anyone has any solution ?
Thanks..
Thanks..
Oh no!!!!! Let's hope the beoconnect software is updated!
Have you asked beocare?
David
I have the same problem.
Does anyone has any ideas?
J.
Hi
I received this response from BEOCARE:
Hi
Yes it works and using a piece of software called carbon copy now my bs5 and iTunes libraries are always in sync!Can't copy playlists though.Hi I received this response from BEOCARE: I am sorry to inform you that BeoConnect is not compatible with macOS Sierra, and the following procedure must be followed in order to transfer content to the BeoMaster 5: • On BeoSound 5 in SETTINGS -> NETWORK INFO, the IP address of BeoMaster 5 is written • On Mac, open Finder - in top bar select "GO" - "Connect to server" • In server address type: smb:///bm-share$ • Provide 'BM-USER' as user and the password stored in SETTINGS -> NETWORK SETTINGS -> CLIENT PASSWORD on BeoSound 5 • Now select the server in Finder: Shared -> IP-address of BM5 -> Music. (or if "connected servers" are shown on desktop -> choose the "BM-SHARE$" icon) • You are now able to drag and drop files from your computer to the music library on BeoMaster 5 I haven't tried it as yet... hopefully it works Beovision 8-40, Beocentre 6-26, Beocentre 2, Beolab 9's, Beogram 7000, Beogram 9500, Beo 5, Beolit 1000, 800, 700, 600, 400, Beocom 6's, Beotalk 1200
Hi
I have tried to follow the instructions and get as far as i can drag and drop files to BM shares.
The problem is, that it opens a new file with every album imported. I don't know how to bring new albums in the row of the existing ones. Any hint?
How do you connect a Mac to the BM5 by cable to have a faster communication?
Thank you and regards
