My 4002 turntable sometimes makes loud squeaking noises while playing (from motor area?).
Also the arm sometimes squeaks when moving, especially at the ends of travel. Sometimes it doesn't come to a full rest when returning to the right and will only park and shut off if I give it a gentle shove.
And lastly, it makes a tremendous rumble at the end of LPs before lift off.
I
lubricated the areas around the axle pivot between solenoid &
damper, the ends of the solenoid, and piston of the damper. Also the
long threaded shaft that the mechanism runs on.
I used Zoom Spout high quality turbine oil, which is paraffin based and non-gumming.
How taught should the drive belt be? Mine seems a bit loose.
What else should I look for?
