Replacing plasma on Beovison 9
Hi All,
I have a Beovison 9 type 9721. The Tv has developed a black strip about 6 inches vertically from the top on the right side of the screen. I'm thinking this could be one of the ribbon connectors along the bottom? It does come and go so I think it is a loose connection.
I'm happy to strip it down and re-seat this or the other plan would be to pick up a replacement plasma.
The question I have is- has anyone tried taking  a BV9 apart? Would using a BV4 as a donor be a good idea is the fix doesn't work? Or could I use a Panasonic plasma (but not sure which model I would go for and any issues on compatibly)
Many thanks for your time.
Thanks again, this is very helpful and pretty much what I was hoping it would be. Did you replace the whole screen unit and can I use any 'type' number' replacement BV4 unit that is an HD variant?  I had been considering getting hold of a Panasonic display but the model numbers thing is a real mine field as there seem to be so many variations. Once I take it apart I'll have a better idea of what is what..
Many thanks
Paul
