Hi All,
I have a Beovison 9 type 9721. The Tv has developed a black strip about 6 inches vertically from the top on the right side of the screen. I'm thinking this could be one of the ribbon connectors along the bottom? It does come and go so I think it is a loose connection.
I'm happy to strip it down and re-seat this or the other plan would be to pick up a replacement plasma.
The question I have is- has anyone tried taking a BV9 apart? Would using a BV4 as a donor be a good idea is the fix doesn't work? Or could I use a Panasonic plasma (but not sure which model I would go for and any issues on compatibly)
Many thanks for your time.
