Hello!
It is the one from the Beosystem 2 I bought on e-bay and that didn't work (almost) at all.
/forum/general-discussion-and-questions/beovision-5-switch-off-every-day-at-the-same-time
I used the PCB from my Beosound 3000 and the firmware and eeprom from the Beosystem 2 and Beosystem 2 started without a problem.
I used the PCB from the Beosystem 2 in the Beosound 3000 (swapping firmware and settings eeprom again) and Beosound 3000 doesn't start (not even the RED Standby Led).
It is obvious that the microcomputer board is defective. It might be just a pin on the connector or a bad solder joint, or it could be a part of the microcontroller (H8/3002) that doesn't work.
I am guessing at the moment that it might be a problem with the infrared pin on the microcontroller (I'll check tomorrow) because the Beosystem 2 reads the settings eeprom, cycles a relay once and then does nothing. If I remove the settings eeprom it keeps cycling the relay. So parts of the board work but not all.
Anyway, I'm waiting for an answer from my B&O dealer, but so far it was not very helpful.
One of my worries is that the Dealer will tell me that I have to replace the whole PCB 14 in the Beosystem 2 as the microcomputer board is soldered to the AVS (PCB 14) board. This AVS board will be much more expensive than the same board from the Beosound 3000.
Regards,
Andrei
PS: do you work at B&O? 😕
