Need help with Gefen Switch
I have a BeoVision10 46" (2 HDMI slots)  and would like to add 4 different HDMI sources (SAT receiver, Apple TV2, BlueRay player, Cable receiver). As far as I know the Gefen switch can handle this and is also controllable via PUC.
The model I wanted to buy (GEFEN HDMI 1.3 Switcher 4x1 1080p EXT-HDMI1.3-44)1 is discontinued and now replaced by  GefenTV 4x1 Switcher for HDMI with RS232.
- Has someone experience with this new GEFEN product. Can I control this via BEO4 and PUC?
- How do I set it up that I can control all of them via PUC?
thanks for your help
hello,
I'm using this one:
http://www.gefen.eu/lshop,showdetail,13103182335129,de,1310318243-5169,1271253059.1271252698,gtb-mhdmi1.3-441,7,Tshowrub--1271253059.1271252698,.htm
Don't know if this is the switch you mean. The RS232 is additional, it also works with IR and PUC is available.
hfat
thanks for the info. So your switch is controllable via BEO4 and PUC?
that would be great...thx..Dobbs
Yes, it is. Works great.
hfat
How is the control using the BEO4 done?
You tell the tv set that you have a expander and you maybe need to update your PUC list so it include Gefen switch, after that you
DVI-1,DVI-2,DVI-3,DVI-4 or Hdmi depend on tv model
You do not use the Beo4 as such. The telly just think it has more HDMI´s so that you can assign them to you different sources.
The PUC is handling the rest, when switching source.
/C
Ah. I See; sweet! Thanks for the clarification!
