MLGW and Somfy Blinds transmitter
Hi, I have recently bought a second hand Master Link Gateway mkII and I'm looking at blind options. Clearly the Lutron Blinds are a known working option, but extensive so I am looking at the Somfy blinds. These blinds have an optional RTS Transmitter that can be feed from a home automation system. Does anyone have any previous experience of interfacing the MLGW with the RTS transmitter with success?
hi corona!
look to the lintronic TT455-RT-238 on http://lintronic.dk you can control the lintronic box via rs232 with custom strings. maybe lintronik can control the somfy transmitter?
we have in the past sent rs232 signals from the MLGW to an elang or RTI processor which then communicated to the somfy via rs485
just remember the somfy has a weird numbering system for the rooms
room number - 1 = number to put in somfy rs485 code creator software
I had the same issue with Somfy blinds and controlling them using the Beolink Gateway. I found this online and thought I would give it it try because it was significantly cheaper than the Somfy RTS transmitter.
Many thanks, this looks like a potential solution.
Thanks, I will look into this and report back
I have used mlgw and connect to somfy rts transmitter thru rs232 and used customstring so it works
Hi, thanks for this, question if I may (I'm not that technical), how did you wire the RS232 to the TRS transmitter?
Tompa,
Can you elaborate?
tompa wrote:
I know in the US market they make a RTS RS232 compatible controller, but for some reason in Europe only the RS485 is available.
