So, you are using the PL, ML and NL connection all at the same time?
>> Sometimes.
Your BS4 and V1 all use / play to the BLs attached to the PL of the ML/NL, right?
No, The BS4 has no speakers and is using the V1 speakers. The BLC ML/NL speakers are independent.
What happens if you play a CD on the BS4 and watch a movie on the V1 at the same time? What audio do the BLs pick up?
This is not an option in my setup, as the BS4 has no speakers. The BLC ML/NL is off or using an audio or a video source. Keep in mind that the BLC ML/NL has two 'independent' functions. Converting ML/NL protocols and an 'Actice Kit'
The V1 also has its own speaker. Do you switch it off or can it be configured to play together with teh BLs?
>> The BLC ML/NL is used as a link speaker and in located a different room as the V1. As such they work independent
When you say that the IR eye allows you to join an active session. Does it start anything if no session is active?
>> It will use the last active source.
I have an ML/NL converter and use the Beomusic app (and it works). Have you tried to use it with your setup?
>> The BeoMusic App does not show the BLC ML/ML
