I am embarrassed to admit this, but here goes. While replacing belts on my Beocord 5500, I forgot to unplug the unit and it was in standby. I touched the metal frame of the drive mechanism against the top circuit board which was in the service position and 'POP'. I found a blown resistor at the R28 location, replaced it to no avail.
When I play back a tape, it sounds like the voices are on helium, even though the tape speed seems correct. All other tape functions seem to work properly, although I have not tried recording.
I then replaced approximately 20 resistors, transistors and caps in the same electric path. Again, no joy. I have come to the conclusion that the area in the board I have been working on is for record, not playback. Again, still not tested because I really do not need it to record.
I can read a schematic to figure out what to replace, but can not for the life of me figure out where I should be concentrating my efforts on this board. Parts are cheap and I do not mind replacing a bunch, although the whole board might be a problem.
So, can anybody tell me where I should be looking on this board? Or perhaps someone has a circuit board for sale.
Thanks for all the help.
