How can you tell (easily) that a BeoSound 4 has the DAB+ upgrade ? Want to check an auctioning BS4 remotely.
After a long time searching I've come across a Beosound 4 supposedly with the DAB+ upgrade...
There is a screen shot on the auction of the BS4 display showing DAB+, but i wondered is there another way to verify its DAB+ ? The shot of the underside shows the usual DAB socket (which my BS4 DAB [not plus] has).
Can anyone suggest some way to verify the BS4 has DAB+ ? Some service menu option or something physically different on the unit ?
This auction seems too good to be true - and a reasonable way of exchanging my DAB BS4 for a DAB+ BS4...
Id be grateful for any advice
I can see that both mine and the auction Beosound 4 are type 2855's  - but i can see on the B&O label for the auction Beosound
"Acc: DMB"
 whereas mine is
"Acc:DAB"
Can anyone confirm if Acc:DMB reflect the DAB + version ?
"Acc: DMB"
 whereas mine is
"Acc:DAB"
Well it took the plunge after having B&O confirm that the serial number had had a DAB+ upgrade. So although Im not sure if the Acc:DMB indicates the DAB+ upgrade - I'm now the proud owner of a BS4 that can get all the DAB+ stations....
So many more options for stations to listen to without ads !!
My 'old' / loved BS4 without DAB+ is now on ebay .... if anyone is interested.
I have the same question. It seems the DAB+ stations are not received. How did you make B&O confirm this? Any email address?
I checked through a local store that the serial number had the upgrade, it didn't take too long and was what I needed for confidence in the Ebay item
Thank you - there is no store in my city, but I will try to contact them in some way :-)
A new version of the BeoSound 4 software was made in order to support DAB+.
it is a later version than stated here: http://archivedforum2.beoworld.org/wikis/revisions/beosound-4-software-change-log.aspx
