Does the MX4000 have a COMPOSITE/RGB mode?
My MX4000 has a green hue on the screen if a RGB SCART is connected. If I connect RCA via scart or wiggle the scart it doesn’t happen? Thinking either dodgy connection or it’s in composite mode and I don’t know how change it??
My MX4002 is fine???
link
Here is me adjusting the scart on the back
link
And here is me swapping between a rca and rgb scart connection
link
Cracked solder joints where the SCART socket is soldered to the circuitboard.
100%. How hard is it to get to the solder points? Seems weird that’s RCA works fine
I’ll have to figure out how all the plastic trim comes off the scart connector. I’m fine working on it, just never soldered scart connections.
