Calling users of beosystem 2 / beovision 4
I have an elder beosystem 2 with a beovision 4 display.
During a repair I lost all the setup values in the system (service menu).
I know that some of the values a component specific, but if anybody can provide the values from their system, then these could serve as a starting point for a new calibration. In the service menu -> picture adjustments i am looking for following values:
Rdr
Gdr
Bdr
Bri
Con
Wpr
Wpb
Rct
Bct
Briof
Conof
Colof
Color temp
Comb filter
Movie mode
Gain adjust
7115
7118
R
G
B
Limit
Color adjust
RGB
Cvbs
Many thanks in advance
Is there really no one in here which can assist me with these values.
Maybe i am the last one on th planet with this old system?
Hello Erik-NL
Today evening I can check my values and respond them to you
hfat
If you have an official BV4, which I assume. Then some of the values are noted on the back of the BV4.
These (calibrated) values have to be set in this BS2 menu.
Oh, I remember things again.
Inside the BS2 there is an aluminium labelled box. (tuner).
On that label, some info has been written.
Look:
in case it helps, my values:
rdr 36
gdr 35
bdr 37
bri 36
con 25
wpr 19
wpb 20
rct 29
bct 46
briof 16
conof 39
colof 16
color temp norm
comb filter on
movie mode on
gain adjust 120 124 +23 +9 -13 on
Beoboddy & hfat - many thanks
