Beosound Stage - LAGS
Hi.
Witch sourc you us When you Get the problem?
is the problem there only on hdmi sourc? Or also with app on the LG tv?
interested to know, because if its only on hdmi connected sourc like Apple TV or 3 parts setup box. I maybe have an idé..
Have you try to change HDMI cable? And did you us the hdmi cable that came included the Stage?
I searc on lg forum, and it seems this problem have Been a while with the LG TV.
but this
It works fine using bluetooth, TuneIn and so on, but the lags come watching TV like LIVE-tv, netflix, YouTube, whatever.
I've tried directly setup with the HDMI cable which came with the stage from the stage ARC-input to the HDMI ARC input, and it does this lag, I tried with 3 different cables, a 4K 2,0 HDMI cable, a discount HDMI 4k cable and the original with the stage - none of them works, I even tried with the HDMI cable there is being used on the Apple TV (which works just perfect!)
I had a visit form a LG supporter yesterday who changed the motherboard, but this didn't solve the problem.
It is not a problem with the stage (we've figured) but with the ARC output the stage is giving the LG tv - there are some softwares that can't be readen by each other. (N)
The problem is the HDMI ARC connection. When my DVD was connected to the normal HDMI there was no interference. Bluetooth was fine. And the 3.5mm connection was also fine. I hope the issue gets resolved. I have gone back to using stereo amp and bookshelf speakers. And since I am only interested in music concerts and opera on DVD I am happy to give up the sound effects for movies. This was my first use of a soundbar (the two stages I bought had the same problem)  I’m not now interested in trying any others. These problems are not just B&O/LG. The internet is full of compatibility tales of woe in relation to soundbars. It’s probably because there is not an industry wide standard HDMI ARC.
Have you connect a set up box to HDMI - A on stage, or directly to HDMI on the LG TV?
It seem its have been reported a case,  if you connect chromecast video to HDMI - A on the stage, work around is connect it directly to LG screen.
I recommend people to share this case directly in the B&O app or true the B&O dealer you both the stage so more information can get to B&O. You can send log file directly in the B&O app, on the product and describe which source it on, and if its only if you connect to HDMI, or its also integrated apps in lg. if you not already done that..
I got four USB inputs on the TV.
1. Using this for Apple TV 4K
2. HDMI ARC using this for the Stage
3. Nothing being used
4. Nothing being used
The Stage is setup directly from the Stage HDMI-TV to HDMI ARC on the TV. Can I connect it to the Apple TV, and then the apple transfer the sound to the tv?
I think you meen HDMI  and not USB?
HDMI 1 Apple TV
HDMI 2 with ARC- Connect down to Stage on HDMI TV on stage.
HDMI 3 and 4 you not use.
Is the drop out sound on apple tv, or apps on LG tv? or both?
Is the drop out there when you play music sources true beosound stage (bluetooth, airplay2, tunein radio?)
Oh sorry, yeah I do mean HDMI and not USB.
The sound drops is on both TV-apps and Apple TV.
The sound do not drop using bluetooth, tune in and such.
Not really sure what you try to achieve...
You have two HDMI on stage, right?
To the other one you can connect the ATV if you want, but you can just as well connect the ATV to the TV directly.
