I might be one of the only others here with a Balance Stereo pair, and I've had very similar issues. I was actually going to send one of my speakers off to B&O for repair, but now maybe I'll hold off.
The right side speaker constantly malfunctions. I've had to factory reset it over and over again because it loses signal and no longer appears in the app at all. What I haven't done yet is try switching the left for the right. I'll do that today.
Question, just to see if you're having the same problem I am - when you look at the speaker settings, does your stereo pair show Left and Unknown? That's what I see most of the time lately.
Do you have 2 non-GA or 2 GA speakers?
Factory resets never helped me either.
I think you could definitely try the same things as I have:
- extend from one speaker to the other, then test
- now swap them around physically, then set them up again but with stereo according to the new position and then test
- test stereo both close to the router and with the speakers placed close to each other
- you could also compare how they work both individually (one is off for example) and in a BeoLink setup joined together
- see if they work better if they are both Ethernet-wired to your router and then setup stereo and test
Remember that my issue is that sound dropping out on the right-channel speaker immediately starts after pressing Play. I can actually see Left and Right labels in the app. I cannot recall Unknown but it doesn’t necessarily mean you have a different problem. Also, I have once experienced such heavy drop-out that even my stereo pair had disconnected itself. Then the speaker on the right was lost and was struggling to come back online and was therefore not recognized by the app. Factory reset did help with it being recognized at least.
