c-larsen wrote:
Okay, I only had the option to send an e-mail, maybe that function does not work.
It sounds like your problem is caused by WiFi interference on the wireless link between the two speakers. Could you answer a couple of questions:
1. Are your speakers connected to a 2.4 GHz or 5 GHz network?
2. Have you changed the default sound quality settings from the app? (default is to use LC3+)
I very much appreciate your kind help! :)
Not too easy questions to answer.
I will take a closer look as soon as I get a chance, right now as I am writing I can only say that any device I connect to my wifi seems to be connected to 5GHz. I just don’t know how this is controlled by my wifi settings. I will probably need to test stereo setup with only 2.4 enabled and only 5 GHz. I have read that in my AirTies 4930 there is an additional chip for extra processing power. On the other hand the 5GHz light indicator on every AP has always been blinking every few seconds while the one for 2.4 has always been lit up continuously. I have not checked if my right-channel Balance would cut off exactly when the light on the 5GHz blinks once, but so far I have a feeling they might be connected to 5GHz and that I might have an issue with this very frequency. I must add I am not a network expert but I will need to doublecheck my theory on a weekend. I have 3 APs and I have tested stereo previously on both the strongest and weakest AP-signal.
Regarding the sound, I am not sure what you mean by LC3+. Sorry if this is very basic :). All I think I have configured for standalone or Beolink is Omni-channel with 2 units of treble added and that the speaker is stood by the wall. After each repositioning I’d run Active Room Compensation. Otherwise AirPlay multiroom and Beolink are enabled as this is what I use the most. With stereo I have noticed that Omni-direction would always change to Forward automatically.
Last but not least something that I have been wondering about is if anybody has ever attempted to stereo-pair a non-GA and a GA-enabled Balance and what would happen. Customer care having checked mine based on serial number they could confirm that both of mine were non-GA. Hopefully this can be trusted, just like the order I placed for my non-GA Bespoke edition at my dealer’s. Strangely the B&O app shows my Bespoke edition as Beosound Balance Google Assistant under the attribute Product type whereas my Nordic Ice is just Beosound Balance. I cannot be 100% sure because of the clues one should look for, but everything except this product type info indicates that my Bespoke one is also non-GA. There is also something called a Type number, which is the same for both speakers. I do not know if this differs depending on if the Balance contains GA. But I do think this can be ruled out.
