Beoremote Halo
Hi dear Members Is there anyone who can give me advice to get access to the battery of the Halo remote? Could not find a service manual, or hints to open the remote from downside, where the battery lives. Mine has gone bad because the battery last only a few hours.   Thanks for reply. Kind regards Christian
Under the rubber foot there are 4 screws, remove them and lift off the battery cover.
Bang & Olufsen classic service centre. Repairs and refurbishment to both old and new.
Hi Thanks for that, I´ ll try next days.   Kind regards Christian
Hi Found the screws under the rubber ring, all ok. Thanks again Christian
